Hi everybody. I'd like your input on my reasoning.
The TV in our office meeting room stopped turning on. It's 100% dead. Nothing happens when we try to turn it on. Plugging in the power doesn't turn on any LED's or anything. Pressing physical power button gives no result. It has been replaced, so they wanted to throw it out, and I figured: I don't have a TV at the moment, let me take a look at it.
I pop it open, and I see there is a yellow power supply PCBA, and a green PCBA, presumably doing everything dealing with running the panel and controls and everything. Visual inspection of either PCBA gives no clues. Nothing sooty and no obvious burned holes on chips or anything. They might be there, but I couldn't see any.
I connect the 230V power cable. The silk screen print on the yellow PCB says it should output 13V through that black cable with the orange connector. I measure, and it's only 11.5V. So I disconnect 230V, disconnect the cable between the two PCBAs, reinsert 230V and measure again, now it's 13V on the PSU output side, and the backlight is enabled across the entire TV panel. I conclude this means the green PCB has a problem (visual inspection gave no clues), so I stopped there and ordered a replacement green board. Used one, from Ebay...
Do you agree with this logic? Do you agree that if the voltage drops from 13V to 11.5V it suggests there is a problem with the green PCBA? Do you agree that simply replacing the green board seems likely to work without any further issues?
By the way, the black boxes are the speakers. No wonder audio isn't great on flat screen TV's. And the picture is upside down. The top of the picture is the bottom of the TV.
PS: I can't find the remote. I can google this, but quick question: Anybody know if it's manageable to "pair" a remote from a different TV to this one...? Just in software menus, I mean.
