Author Topic: Samsung TV QA75Q7FNAW Service Manual  (Read 380 times)
Online EEVblogTopic starter
« on: December 02, 2024, 02:09:06 am »
I'm looking for a service manual for a dumpster Samsung 75" QA75Q7FNAW TV
Or really, just advice on how to get the rear panel off so I can try and put 350V DV up it's clacker to see if the panel is working or not.
No obvious screws holding the back panel on, and a spudger around the outside lifts it off a bit , but there seem to be no catches at all.
So just seeing if anyone know before I go medieval on it's arse. Thanks.
Offline DavidAlfa
Re: Samsung TV QA75Q7FNAW Service Manual
« Reply #1 on: December 02, 2024, 04:48:00 am »
Seems close if not the same:
Offline Josec
« Reply #2 on: December 03, 2024, 03:33:26 am »
May be is like this?
Offline jnk0le
« Reply #3 on: December 04, 2024, 09:53:08 pm »
Different model but, in my case wire pull didn't work.
Can't find the exact video with fullest explanation, but this one is the closest to how it works: https://youtu.be/g0ojfT2rJtQ?si=NB2cQrZdMSg6ET52&t=113
The unit was most likely dumped due to burned backlight leds. Which, of course, burn together with the diffuser.
« Last Edit: December 04, 2024, 10:05:45 pm by jnk0le »
