Author Topic: Samsung SyncMaster T240 LCD screen problem  (Read 1710 times)
Offline stdcallTopic starter
  • Country: il
« on: October 16, 2015, 11:40:09 am »
Hey guys,
I'm been troubleshooting quiet a while with my LCD screen.
First, there were these 2-3 seconds blackouts where the screen got black.
I replaced all the bad caps, and the issue was stable for about a year.
Then, it happened again, but the caps were OK.
So I replaced the backlight inverter.
The issue was solved, no blackouts. but now, I have these weird green and pink pixel spreaded on the screen. (I attached an image)
I'm quiet positive that it's related to the power supply board.
What could be the issue now ?
Offline Totalsolutions
Re: Samsung SyncMaster T240 LCD screen problem
« Reply #1 on: October 16, 2015, 03:33:35 pm »
You did use new, branded low esr caps ? ------
Sent from my GT-N7100 using Tapatalk
Paul
