Hi, i'm new on this forum but i'm here to get some help with a samsung tv.
What it does is when powered on the backlight flashes on and then goes out. With the t-con board and all other connectors disconnected from the mainboard the problem is still there.
When i disconnect the mainboard the backlight stays on.
I have checked the caps on the output side of the power board, these tested ok.
I have swapped out the power supply board, this didn't solve it.
Does anyone here have experience with this kind of stuff?
I have made a short recording of this problem..
