Author Topic: SAMSUNG UN39EH5003 SCHEMATIC  (Read 1286 times)
Offline PKTKSTopic starter
  • Country: br
« on: December 27, 2020, 03:10:35 pm »
Hi there..  I have to check some points on the model
already on the bench
The service and repair guide already exists on some
paid per view sites..  any hand appreciated on this
Thanks
Paul
Offline fzabkar
« Last Edit: December 27, 2020, 08:24:24 pm by fzabkar »
  • Country: br
Re: SAMSUNG UN39EH5003 SCHEMATIC
« Reply #2 on: December 28, 2020, 12:26:02 pm »
Are any of these suitable?
https://elektrotanya.com/showresult?what=UN39EH5003&kategoria=&kat2=all
Yes right  on the spot..   the test points with voltages are there..
The piece attached failed the first OHM probing check
on the power board..  it is dead shorted.
I am having a hard time identifying the label because
the board is coated with a strong varnish that clouds the
codes..
It looks like a Schottky like
https://br.rsdelivers.com/product/on-semiconductor/mbrs340t3g/on-semi-40v-4a-schottky-diode-2-pin-do-214ab/1138677
but the SMD marking as usual is not related with ONSEMI internal
datasheet reference codes.. (like MBRS340T3G)
If anyone has a clue about what is this piece code
drop a handy help...
Thanks a lot fzabkar.. appreciated   :-+
Paul
  • Country: br
« Reply #3 on: December 28, 2020, 02:26:41 pm »
these f***  SMD codes wastes my patience
U3J  MURS320T3  FR diodes
https://www.onsemi.com/pub/Collateral/MURS320T3-D.PDF
blabla ultras fast .. resilient...   dead shorted.
Paul
Offline fzabkar
« Reply #4 on: December 28, 2020, 05:18:50 pm »
http://www.smdmark.com/en-US/search/code?id=u3j
The first link in my previous post has a circuit diagram.
« Last Edit: December 28, 2020, 05:25:43 pm by fzabkar »
  • Country: br
« Reply #5 on: December 29, 2020, 05:03:53 pm »
That circuit does help a lot. Although some light different
things they almost match.
That diode is technically shorted by those resistors
with less than 3 ohm to ground. That is why deceives
any instrument while blinding ohm probing.
Assuming that is just a clamper and will probe all board again
using that schema as support..
Thanks again...  :-+
Paul
