Hey guys thanks for your response.
I didn't want to make it a long story, so here's some context. This came to me doing nothing other than coming out of protect. It was so dirty the first step was to brush with one hand and vacuum with the other. Bugs, dirt, you name it, needed to be cleaned out. I recapped while I went through it cleaning. First issue was a fluctuating power supply, measured, tested and replaced the 2 transistors on the power board. Power went to the 36VDC it was supposed to, and the unit began playing semi-reliably. AKIM, I tested those transistors with a Peak DCA55, and it called them good. I had the replacements and put them in even though the test said I didn't need to, and it solved the problem. So, testing is great, but if you're not testing under load... So my strategy wasn't to replace everything in sight.
I've been testing/listening to this for just about 2 hours and have had one self-correcting hickup, where the left side bumped but immediately dropped back to normal and kept playing. This after I re-cleaned the push-button switches with DeOxit. While doing that I noticed the metal shield over the Volume/Balance board (F-2543?) was not sitting correctly over the board, but had slipped over to one side. Straightened it and started to test.
Do you know what the metal shield is supposed to keep off of the Volume/Balance board? Do you think the shield being out of place could have allowed whatever it was meant to shield to interfere with one side via the balance?
