Author Topic: Venom Dual 2-10 Amp Lipo Charger?  (Read 2105 times)
Offline Technoman
« on: July 22, 2014, 02:16:13 am »
 Hey folks! This is my first post here and I don't know if any of your are familiar with Lipo chargers for Remote Control Helicopters but it shouldn't matter I don't suppose.
 The problem I'm having is this.... I plugged in a 4 cell Lipo battery to port 2 of my Venom Dual 2-10 Amp charger yesterday and I heard a tiny pop. Since then the charger gives a broken connection error message.
I've taken the case apart to look inside to see if there was something obviously wrong with the charger but found nothing.
 Where do I go from here?
There are some fairly large capacitors on each port and I wonder if the one on port 2 might have failed.
Or maybe I should look elsewhere?
I've fixed a few things on circuit boards long as someone can point me in the right direction or if there is something obviously burned out. I don't know a lot about tracking down an issue when none is apparent.
 Any help would be greatly appreciated.
« Last Edit: July 22, 2014, 09:16:49 am by Technoman »
Offline Flump
Re: Venom Dual 2-10 Amp Lipo Charger?
« Reply #1 on: July 22, 2014, 02:44:34 am »
some good internal pictures of both sides of the circuit board would help :)
Offline Technoman
« Reply #2 on: July 22, 2014, 09:17:38 am »
 Here are some pics. Let me know if another angle is needed. Thanks.
« Last Edit: July 22, 2014, 10:25:35 am by Technoman »
Offline Technoman
« Reply #3 on: July 23, 2014, 02:30:32 am »
 Now both ports in the charger are dead. I plugged a battery in this evening and heard a tiny pop just like port 2 did and now I get a broken connection error message on port 1 as well.
I think I may have some blown mosfets. I took the heat sink off this evening and I can see two areas of the board that have gotten pretty hot. There in the same place on each port. Each spot has a cluster of 4 MOSFETS.
Can I test those in the board? I'm getting a reading on some of them after opening the gate but not all of them. I can't get my pics to load now. I'll try again later.
 If you look at the 2nd pic on the back of the board there are 2 dark areas. The mosfets are on the other side of the board in those dark areas.
Offline Technoman
« Reply #4 on: July 23, 2014, 09:51:36 am »
 Here are the pics with the heat sink off. You can see the two dark areas surrounding the Mosfets.
Both sides
Right Side
Left side
« Last Edit: July 23, 2014, 09:53:48 am by Technoman »
Offline amyk
« Reply #5 on: July 23, 2014, 12:05:30 pm »
I don't see any images...
Offline Refrigerator
  • Country: lt
« Reply #6 on: July 23, 2014, 01:45:45 pm »
No pics, mate. Better get em up quickly, i want to see those boards.   :D
Just started a blog at http://brimmingideas.blogspot.com/ . Not much in it as of now but more is sure to come :)
Offline Technoman
« Reply #7 on: July 23, 2014, 11:13:47 pm »
 Can I upload the pics here are do I have to have them uploaded elswhere?
I can see them here, I guess they are blocked somehow?
