Author Topic: Sartorius Ge 512 0ce will not turn on  (Read 668 times)
Offline Keno1981Topic starter
  • Country: al
« on: June 09, 2024, 02:52:25 am »
i just got a used balance of sartorius GE51- 0ce model but it will not turn on when i push the on button. before shipping it was ok. any help is welcome. thanks
Online tunk
  • Country: no
Re: Sartorius Ge 512 0ce will not turn on
« Reply #1 on: June 09, 2024, 10:42:03 am »
Open it and see if there's anything obvious like loose wires or connectors.
Does the PSU deliver the correct voltages?
Offline Overspeed
« Reply #2 on: June 09, 2024, 11:27:12 am »
Hello
open and check with a multimer IF yes or no the PSU works
Regards
OS
Offline Laval
« Reply #3 on: June 09, 2024, 11:50:37 am »
Also, check if there is a fuse that might be blown. You may have to open it to do that.
I would rather have questions that can't be answered than answers that can't be questioned.
- Richard Feynman
Offline ratmole
  • Country: gr
« Reply #4 on: October 17, 2024, 12:58:45 pm »
there is a transistor on the top right corner marked as AH-16. Most likely it's defective.
Try to short the Collector-Emitter and see if the unit power on. If yes, change the transistor and you are good to go.
if i'm not mistaken here is the datasheet :https://www.onsemi.com/download/data-sheet/pdf/bcp53t1-d.pdf
