Hi again, dear EEVblog community!
I hope you're doing well during this Covid crisis
Interesting question for you. I hope some of you are experienced in using/fixing precision scales, or should I call balances.
I have a Sartorius CP324S balance, that I bought used.
The problem with it is that while it seem to work flawlessly; repeatability, accuracy, sensitivity is very much OK, it drifts badly with off-center loading.
Its a 320g capacity balance, with d=0.1mg, with internal calibration.
I tested it with a 50g weight, but it changes as much as 0.0400g if I place the weight on different places on the pan. With a 1g weight, it changes zero..
It has a "monolithic" force restoration-type load cell, which has two screws for adjusting this phenomenon, but the manual calls for +-0.0003g of off-center drift. I am not sure if 0.0300 can be fixed with them.
I leveled the balance multiple times, properly preheated is, the pan is not bent, nothing seems to be loose, binding, etc. Everything seems to be in order, except the off-center thing.
Considering I bought it for about 70$, it is still a bargain for me, but I hope somehow it can be fixed.
Have a nice day and thanks for your attention!
