I am working on a Tektronix 284 pulser and the tunnel diode is acting strange. There was a very intermittent short in it and I have seen it pulsing a little. In digging further ALL the biasing resisters are out of spec. The 2 series resisters in the back of the air line are 739.9 Ohms they should be 660 Ohms 5% the front resister is 797.0 Ohms it should be 750 5% closer but still out from the 5% spec. The air line termination resister is spot on at 54 Ohms. With the bias controls the wave shape will change but the square wave is messy not a clean step I would expect. My question, is the tunnel diode is still good? I did a diode check on it and I got .6 V in both directions so it is not dead shorted. But this is to be expected from a TD. This is the infumas D180 from Tektronix. I can source a new part if it need to but it is $250.00 Each Yikes. Is this worth fixing or should I put it up to a learning experance?
