Hi All.
I'm attempting to fix high-end power supply but puzzled due to inexperience in this field. I would like to obtain some help and directions.
What I did so far:I reverse engineered the control circuit of power supply as googling it failed:
I desoldered blown transistors (Q7 and Q5)
I checked all other transistors, they all were bad except Q9
I checked in-circuit all capacitors if they are not shorted (non so far)
I checked all diodes in-circuit
I desoldered zener D6 and created simple resistor + zener circuit and it did not hold anything close to 15V (it did not hold anything at all).
Now I have depopulated control circuit that made it easy to measure resistor values and find one that became open circuit - R13.
The problem for me here and the reason I'm writing this are blown beyond recognition transistors (or maybe they are not transistors)? To understand what they are I tried to understand their functions.
For Q7:I googled zener + transistor circuit and found that Q7 is emitter repeater that repeats zener voltage minus 0.7V, so I guess Q7-D6-R18 form a stabilized power supply for all the control circuitry. Thus, even without any available designation on Q7 I can safely assume that it is NPN transistor and going to use 1P (MMBT2222A) as in many other places on the board.
Was I correct here?
For Q5:I googled transistor-transistor circuits and it came up with different variations but somehow similar latches. They all use back-to-back complimentary transistors, like Q8-Q9 (1P-2F).
Function of Q8-Q9 latch became clear immediately -- upon signal from secondary side via optocoupler to pull down FB line of 1377B which according to 1377B datasheet disables switching of power MOSFET (probably some kind of overload protection).
Function of Q5-Q6 is not clear to me:
-- Can Q5 be not a transistor but some kind of voltage regulator?
-- If it is indeed a transistor, why didn't they use 1P like everywhere else on the board? Because I can clearly see second symbol is "2", not "P"?
-- If is is indeed a transistor, could it be a latch with a delay: it will be triggered when C12 is charged by pulses from Drv pin of 1377B. Resistor R7 is large, so it will take some time to charge C12. Once C12 is charged, it will open Q5, which will open Q6 and power will be supplied to Power Factor Correction IC thus enabling power correction.
Will I be right to say that Q5-Q6 is a latch that will delay power supply to power correction IC?
Thanx, Sergiy
