I have a seagate barracuda 7200 hard drive that I have removed from my mother in laws computer to replace with a larger unit.
Although it works there is what appears to be a blown diode on the board just above the sata power connection and next to an inductor. The one adjacent to it is labeled 54 40 google shows this a schottky diode, is this correct as the ones shown are all axial leads and I cannot find them as smd's.
Sorry about the photo quality I used my phone
You might have taken a sharper picture... I've seen case like this. It was a blown TVS across HDD power connector.
I presumed that the cheap low-quality computer PSU started to generate high ripple voltage because of the capacitors degradation, TVS tries to cope with that and died
Surprisingly, HDD worked well after I desoldered blown TVS.
Check the computer PSU, next time it may blow something else
