Author Topic: Search: Casio power cord connector  (Read 1809 times)
Offline NottheDan
« on: May 20, 2017, 08:48:56 pm »
I just got a Casio AS-L desk calculator (from the very early 70s), unfortunately without power cord and it uses a connector I'm not familiar with. Does anybody know where I can come by plug for it?
Offline Nusa
Re: Search: Casio power cord connector
« Reply #1 on: May 20, 2017, 09:42:54 pm »
A straight-on picture of the connector and a height and width measurement would be helpful.
Also confirmation on the input voltage printed on the case, so we know if we're looking for a mains cord or an AC or DC adapter.
« Last Edit: May 20, 2017, 09:45:57 pm by Nusa »
Offline NottheDan
« Reply #2 on: May 20, 2017, 10:00:41 pm »
It's a mains cord.
Offline helius
« Reply #3 on: May 20, 2017, 10:00:51 pm »
Some old Roland keyboards used that connector type.
Offline Lorenzo_1
« Reply #4 on: May 23, 2017, 09:52:06 am »
There are some HP cords that might be compatible on Sphere's new arrivals page. Don't know if they're the same but might be worth a http://www.sphere.bc.ca/test/new.html#catalog
Offline NottheDan
« Reply #5 on: May 23, 2017, 08:09:17 pm »
I don't think they are the same. Very similar but not the same. But thanks to your hint I think I found the correct one: https://web.archive.org/web/20160802081036/http://www.cs.ubc.ca/~hilpert/e/powerConn/index.html#jCalc
And I don't think I'll have much luck getting one. Bit of a shame really.
Offline Nusa
« Reply #6 on: May 23, 2017, 10:29:35 pm »
If you can find individual pin sockets that fit those pins snugly, you may be able to create a one-off solution with either silicone rubber or a non-conductive epoxy. I bet you can use the receptacle itself as a partial mold. Experiment on something else as a proof of concept, of course.
Offline mgraves235
« Reply #7 on: May 26, 2017, 06:20:01 am »
is replacing that socket with a standard iec out of the question?
Offline NottheDan
« Reply #8 on: May 26, 2017, 11:50:54 am »
No, it is not. But I'm trying to keep it in as original a condition as possible. Also, it is a 115V device and line voltage here is 240V. I'm a little bit worried that, if I put a standard IEC socket I'll do something stupid and thoughtless with it and a standard power cord.
