Author Topic: Search: Rotary encoder knobs used in Keysight InviniiVision Scopes ...  (Read 3505 times)
Offline _Harry_Topic starter
Hi guys,
for repair I'm searching the OEM brand/type of that 24 pulses/360° rotary encoder with pushbutton switch, what's used as e.g. trigger knob, channel offset knob, ...
The encoder shaft diameter is 6mm, length of the visible part of that black plastik shaft is 9mm (7mm flattened for the knob), no detent.
One more detail:
The shaft has a "groove" on the top end and sidewards on the flatten side. Almost every encoder of that kind out there has no groove on the flattened side. Seems like Keysight is using a special manufacturer ... could not find exactly that looking encoder somewhere.
Any ideas?
« Last Edit: May 17, 2017, 08:13:50 pm by _Harry_ »
_________
 - Harry
Offline carl_lab
« Last Edit: May 17, 2017, 07:54:36 pm by carl_lab »
Thanks carl for your fast reply.
First - I'm already googling since many hours  ;)
Yes, the ALPS encoders of that kind look very similar.
But when looking into the data sheets of ALPS EC12 series encoders I can't find one with the groove on the flatten insulated plastic shaft.
(have my description above little more specified)
« Last Edit: May 17, 2017, 08:30:00 pm by _Harry_ »
_________
 - Harry
Offline stj
if it was Alps it would say it on it.
Offline Jwalling
  • This is work?
Does the knob have a matching "bump" to fit in the slot?
Jay
System error. Strike any user to continue.
Offline carl_lab
« Last Edit: May 20, 2017, 11:23:15 am by carl_lab »
@Jwalling: No
@Carl: Yeah ... I found many encoders like that.
But I'm searching for the exactly OEM one (won't risk that something doesn't work well / quality reasons)
_________
 - Harry
Offline Armadillo
I once dismantled and teardown a HP encoder. There are active chips with wire bonding inside much more complex than simple IR or mechanical encoder.
I ended up fixing a priced encoder to a priced instrument without spending time to decipher the encodes.
