Good day fellow EET´s and electronics enthusiasts ! I was repairing old faulty -mining -oxidized Seasonic 1kW ATX PSU. After i found the fault and confirmed normal operation of the PSU under at least light load, i decided to replace it´s output capacitors for the 12V rail because of their moderate degradation.
Even i´m using metcal i had more than usual problems removing the one of the 3.3mF capacitor which was held in place by glue. When pulling the cap with moderate force i snapped in half one of the ferrite. And now .. of course the ferrite inductor has different
properties compared to flawless part pulled from the same circuit.
Im not aware of the switching frequency range of this part in normal operation.
But reading with LCR45 on undamaged part @200kHz:
Ind/Res 0.01Ω
L=~0.07µHBroken inductor @200kHz
Ind/Res 0.01Ω
L=~0.04µHI skipped writing down the complex values because they were fluctuating, and this lcd45 device is mostly hobby grade i think.
Not tested the psu under load after this incident, i only have programable electronic load up to 400W and RTX3080Ti/RTX3090 to push the load further. But could become expensive and stupid real fast if the PSU acts up.
I guess i have not many options to replace or repair the part. I´m just fixing junk like this and donating it. But i hope some of you have an idea how to proceed with the repair or simply abandon it ?
Best regards
