Hi all,
I am slowly working through the restoration of a TDS540.
All caps on the acquisition board replaced and board cleaned.
I now have two issues with the scope and, as I’m a bit out of my depth here, am hoping some smarter than me in the forum could offer some pointers in where to go next.
When powered up from cold, the ubiquitous acquisition failures are listed, but if left on for 5 or 10 min and then retried, it passes. During this warm-up time, the trace vertical position drifts upwards, starts out off-screen. So far have not found what is drifting. Could probably live with this one though.
More troubling is the second issue. If the timebase is increased into the extended range (>1Gs/s), the trace breaks up. Basically I end up with a dashed line making up the trace. If more than 1 trace is active then it starts at 500Ms/s. I’m guessing maybe a memory fault? But is this going to be on the acquisition board still, or should I looking on the processor side of things?
Any help much appreciated.
Ralph
