that one diagram is all I have been able to find for the Sega Genesis MK1 and I'm not even sure it is the correct board revision.
For some reason I can find plenty of Service manuals for the Sega Genesis MKII though
What are the primary specifications needed for choosing a new Capacitor, Capacitance and voltage?
The capacitor I'm looking at replacing:
It is
surface mount.
It is
ceramic.
I don't think it is
polarized.
Voltage rating? As long as i'm equal to or higher than the original I'm ok ?
Capacitance ? There is probably no way to measure the capacitance since the part is damaged.
I'm not sure what changing the capacitance rating does, too low and It can't store enough energy? Too high and it ____ ?
I found this list of all the electrolytic(only) capacitors in the Genesis Mark 1 VA3, not really helpful since it doesn't list the ceramic capacitors though.
Label
Voltage Rating (V)
Capacitance (uF)
C1 16 220
C13 16 10
C23 10 100
C24 10 100
C30 16 10
C31 16 10
C32 10 220
C38 16 10
C4 10 100
C40 50 1
C41 10 10
C42 50 1
C43 16 10
C44 50 1
C49 10 100
C5 16 10
C50 10 220
C51 10 220
C52 10 100
C53 10 100
C55 16 10
C57 16 10
C58 50 1
C59 16 47
C60 16 47
C61 50 1
C62 50 1
C63 16 47
C64 16 10
C65 10 47
C66 10 47
C67 10 47
C68 10 47
C71 16 10
C72 16 10
C74 10 100
C79 16 100
C86 10 100
JP1 10 47
