Author Topic: Sencore DVM56  (Read 1421 times)
Offline Vintagevalves
Re: Sencore DVM56
« Reply #25 on: January 17, 2019, 04:06:48 am »
Also, let me rewind a bit and restate that when I got this thing the +5V regulator was dead.  I'm not sure how or why it became that way.  This could be part of the solution.
Re: Sencore DVM56
« Reply #26 on: January 17, 2019, 08:49:13 am »
 5V  5-10hz P-P square(ish) wave out of my old Leader audio generator into pin 4 of the LD120 still results in no output on the LD120.   +15 an -12V present on correct legs and grounds trace out.  Dead LD120???
Offline Chris56000
Re: Sencore DVM56
« Reply #27 on: January 23, 2019, 08:41:42 am »
Hi!
I would obtain another LD120 before you go any further with your meter!
A quick check you can try is to lift pin 15 of the LD120 and leave it floating temporarily, this should cause the display to flash "888.8" continuously – this device is noted for internal failure!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Re: Sencore DVM56
« Reply #28 on: January 27, 2019, 09:15:27 am »
Swapped the LD120 with no improvement.  :--
I think I'm ready to give up on this thing and move on to more fun projects.  As cheap as used much more modern DMM's are on the used market I don't see any reason to put more time into this thing.
I'd probably be willing to ship this thing to anyone who wants it for the cost of shipping.  Mostly re-capped, PSU has had all the carbon comp resistors replaced.  I have lifted and repaired a few traces on the function boards.  :-[
Offline Chris56000
Re: Sencore DVM56
« Reply #29 on: January 28, 2019, 06:53:20 am »
Hi!
PM sent - I've decided to take it on as a challenge I can't resist!
Chris Williams
« Last Edit: January 29, 2019, 07:49:04 pm by Chris56000 »
