Hey Guys,
My LC103 has developed a problem as of late and wanted to pass the symptoms around to see if anybody else has experienced this before:
The meter basically works great on every mode but leakage test.
The meter lead zero functions correctly, the cap value function works correctly, Inductor test works correctly,
ESR acted a little funny as it sometimes would give a negative value, but the leakage function is amiss.
Below 50 Volts the leakage function works fine best I can tell, above fifty volts the progress bar only moves about 1/4 the way over and fluctuates some.
It's been doing this for a while.
measured voltage on the red and black wires between the two pc boards and it shows about 50 volts when checking for leakage at 100 volts.
Curius that everything seems to be in threes on what I guess is the voltage generator board.
Thanks for your thoughts on this.
