Author Topic: Sennheiser K6 mic power module schematic  (Read 553 times)
Offline peteb2
« on: May 31, 2018, 10:24:41 pm »
After trying two downloadable "Service Manuals" websites and parting way with the princely amount of USD$5 each time for the unit's service manual but ending up with what is the operator's instruction set, does anyone have the page with the schematic please?
I am trying to help out a chap whose hobby of making wedding videos has seen his K6-M6 shotgun mic to have developed a nasty random crackle even though i have tried tightening the 'earthing' screw in the body. I think one of the pins in the socket has cracked the solder off the circuit board...
Offline floobydust
Re: Sennheiser K6 mic power module schematic
« Reply #1 on: May 31, 2018, 10:45:58 pm »
Usually it's dirt, spit, lint etc in the capsule or a cracked solder joint.
Is it on battery or 48V phantom power it crackles?
Found this schematic.
The following users thanked this post: peteb2
Offline The Soulman
  • The sky is the limit!
« Reply #2 on: May 31, 2018, 10:49:01 pm »
It is not a very advanced device so repairing it without a schematic shouldn't be to difficult, especially if it's a bad contact/solder joint as you mention.
Also make sure the battery contacts are clean and tight.
Good luck.
Offline peteb2
« Reply #3 on: June 01, 2018, 02:26:13 am »
Awesomely indebted guys.... There's one obvious pin where the XLR cable goes in that wobbles a lot more than the others so i bet it's cracked the solder to the board ... or the flexi-loom by the looks. We'll work through pulling it apart and see what gives.... Interesting circuit. I never knew mics could be made so they're so dang complex!
