Took a chance on a set of 3 thrift store power supplies wired in parallel only to find the huge caps on one were toast and all three have corrosion damage. Cracked open a 2nd one, and the big caps test good. Possibly just one went out. I have not yet powered on any cause they were also pretty grimy so removed fans and cleaned up two a bit. Looking for some advice on where to start troubleshooting. Some questions:
1. Not sure what the "staggered" traces are on back of board but the ones next to the very bottom of each board have the most corrosion. Wondering if building up solder there, or even bridging the worst ones together would be a good idea or will this only screw things up more?
2. Should I power up the one with good caps or make some more tests beforehand? Would be great to get at least one of them working since Meanwell is decent quality, also looks like voltage and amperage are adjustable from approximately 20V to 55V and amperage limits of 6A to 16A if I understand Meanwell's manual correctly. These would make a good high power adjustable ps for my induction heating project, etc.
3. The two blown caps are 330uf @ 400V. Do these require low ESR type & cost?
4. Not sure if this blue component blew up, was weakened by corrosion, or came off while brushing/cleaning or some combination. In the picture it's placed where it was approximately. It tests open at room temperature.
3. Any advice on tests, repair would be greatly appreciated.
