Author Topic: SH6GC - Regulator SMT code help  (Read 1088 times)
Offline PKTKSTopic starter
  • Country: br
« on: December 18, 2021, 03:22:07 pm »
Hi there...
Having a hard time trying to find the proper datasheet
for this regulator...
I know for sure it is a regulator..
I guess with pretty confidence it should be a boost...
nah...  re-scanned circuit and actually more like an LDO
All I have tried so far leads to the TOREX XC6371 in SOT89-5
It happens that the package may look like SOT89-5..
but it is not like that.. there is no tab on the top
and the pin out for this XC6371 it totally wrong..
Measured and  got circuit with VCC/GND pins..
Above the chip there is a COIL... 2 caps IN/OUT..
Pretty sure is a boost.. (re-scanned..)
nan.. almost bet should be an LDO..
Any educated guess on datasheet is welcome..
Thanks
Paul
« Last Edit: December 18, 2021, 03:42:22 pm by PKTKS »
  • Country: br
Re: SH6GC - Regulator SMT code help
« Reply #1 on: December 18, 2021, 03:47:24 pm »
... there is a companion ..
should be the booster.. coded  SG4KH
the LDO  LR1101 from UNISONIC may fit using  SOT-25...
SG4KH with the schottky diode marked 76...
So far my guess for that...
SG4KH w/diode  "76"  ==  TOREX XC6371 in SOT-25 ???
SH6GC equals LDO LR1101 in SOT-25 as well...
Any guess welcome
Paul
« Last Edit: December 18, 2021, 03:51:45 pm by PKTKS »
  • Country: br
« Reply #2 on: December 18, 2021, 04:25:27 pm »
It just can not be that TOREX chip..
Pins do not match at all..
Dead sure this is a booster and got it working 25V
Paul
Offline fzabkar
« Last Edit: December 18, 2021, 11:08:02 pm by fzabkar »
The following users thanked this post: PKTKS
  • Country: br
« Reply #4 on: December 20, 2021, 03:26:34 pm »
FB = 25V x 10 / (180 + 10) = 1.32V
If you can measure the actual FB voltage, it might make it easier to search for the IC.
Yes right on spot 1.32V on FB pin..
It does match the pinout but the marking codes are other...
I would never find that candidate .. thanks :popcorn:
the other regulator is indeed a generic 3.3V dropped by
a single diode to 2.6V..
That thing feeds a FUTABA VFD.
Thanks a lot  :-+
Paul
« Last Edit: December 20, 2021, 03:28:23 pm by PKTKS »
  • Country: br
« Reply #5 on: December 21, 2021, 01:07:59 pm »
MANY MANY THANKX for your help    fzabkar
That was a winner service repair...
The gizmo is back to life...  ^-^
Paul
