Author Topic: Shaded Pole Induction Geared Motor  (Read 479 times)
Offline JasonbitTopic starter
  • Country: br
« on: October 09, 2020, 09:24:04 pm »
Hello Folks,
I am searching to this motor (please see attached). I only found this website (http://motor-park.com/sub/sub02.php) where I can see the model. I already sent an email to this emails (http://motor-park.com/sub/sub11.php). One of them isn't works and another (hotmail) maybe I never receive an answer. Do you know where can I found this type motors?
This set it is compost to two pieces (motor plus gear box).  I need this two items (equal or similar).
Thank you all
[UPDATE1]
I am a newbie on this jobs  :D
I am googling about Shaded Pole Induction Motor, because this is the type of the motor with geared coupled. I think I can purchase the two separate items. For this I need understand  what do these values mean:
1:47
04.
08.
19
I am search to brands where I can find information about nameplate to learn about this parameters. If you can share with me manufactures for me to learn I will appreciate.
Thanks
« Last Edit: October 09, 2020, 09:39:59 pm by Jasonbit »
Offline TheMG
Re: Shaded Pole Induction Geared Motor
« Reply #1 on: October 09, 2020, 10:37:17 pm »
1:47 would be the gear reduction ratio
04. 08. 19 most likely the manufacturing date
Part number although close, does not exactly match any of the examples on the website you found and the drawings look slightly different that the one in your photo, particularly the orientation of the gearbox.
My guess, this is probably a custom part manufactured for a specific OEM. If this is for a repair, have you tried contacting the manufacturer of the equipment to get a replacement?
What exactly is wrong with it? Most common failure of such motors is lack of lubrication, that can usually be easily fixed. If it's a stripped gear then that might be more problematic.
« Last Edit: October 09, 2020, 10:43:39 pm by TheMG »
The following users thanked this post: Jasonbit
  • Country: br
« Reply #2 on: October 09, 2020, 10:39:51 pm »
It means that the two pieces are sold together... thanks
