Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Share your techniques for replacing a multi-gang rotary switch
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Share your techniques for replacing a multi-gang rotary switch (Read 1154 times)
Bargainhunter
Regular Contributor
on:
January 31, 2023, 04:45:48 pm »
I have to replace a multi-gang rotary switch in a marantz receiver. I'd like to avoid any mistakes so the best option would be to move one wire at a time from the old switch to the replacement switch. I've attached a photo which shows the switch. As you can see there is no room to place the replacement switch along side the original so I can move one wire at a time. I have taken a lot of photos. There are many wires the same color.
Would you share your past experiences and techniques on how you went about replacing such a switch.
Thank you for your input.
Chuck
Logged
Bargainhunter
Regular Contributor
Re: Share your techniques for replacing a multi-gang rotary switch
Reply #1 on:
January 31, 2023, 04:47:50 pm »
Attached is the photo.
Logged
shakalnokturn
Super Contributor
Country:
Reply #2 on:
January 31, 2023, 07:10:09 pm »
Applying some sort of code to ends of wire insulation + old and new switches with 2 or 3 different coloured markers / paints ?
Logged
Bargainhunter
Regular Contributor
Reply #3 on:
February 01, 2023, 09:16:47 pm »
Thanks for your suggestion.
I ended up labeling the wires as you suggested.
Chuck
Logged
Tomorokoshi
Super Contributor
Country:
Reply #4 on:
February 03, 2023, 02:27:58 am »
What is the problem with the switch?
Logged
eetechTom
Contributor
Country:
Reply #5 on:
February 03, 2023, 02:51:05 pm »
Is that by any chance a Marantz receiver?
Logged
shakalnokturn
Super Contributor
Country:
Reply #6 on:
February 04, 2023, 02:20:24 pm »
Quote from: eetechTom on February 03, 2023, 02:51:05 pm
That was also my first thought seeing the photo. Not that certain after all, I'd say definitely Japan-made.
Logged
Bargainhunter
Regular Contributor
Reply #7 on:
February 06, 2023, 04:30:38 pm »
Yes. This is from a Marantz receiver.
The bottom left section was completely broken off. See photo.
I'm not sure how it happened as there is no damage to the case or face plate.
I replaced the switch and the unit is working fine.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
