Author Topic: EEVBLOG - Brymen BM235 Meter problem  (Read 7085 times)
Offline EEVblog
Re: EEVBLOG - Brymen BM235 Meter problem
« Reply #25 on: July 27, 2019, 04:20:01 am »
Well no reply, no update - ZERO Response .... very lame buy a $$ meter and its throw away garbage. Buy throw away garbage and it lasts longer. My $17 meter from aldi with Auto Voltage, temp sensor etc works great.
thanks for nothing , big let down trying to support local ...
owell lesson learnt again.
There is no BM235 on my mailbag shelf. Also just noticed this thread is from 6 months ago.
Also, no record of an email from your email adress listed on your forum profile, nor any email based on your fall name. Several email from a Robert about the BM235, none from you about this issue.
So  :-//
Offline ricardomardi
  • Country: ar
« Reply #26 on: December 26, 2020, 09:19:19 pm »
Thanks so much for your post and instructions! It worked wonders for my BM257s. I was looking everywhere and finally found it here. Mine issue was that the Ohms meter function was not happening, I would select the Ohms range and it would just show a, 'Ohm' symbol. Fixed it in two secs.! Cheers to all and a happy new one for 2021!!!
  • Country: ar
« Reply #27 on: December 26, 2020, 09:22:06 pm »
A big thank you to 'Ordinaryman1971'....Thanks so much for your post and instructions! It worked wonders for my BM257s. I was looking everywhere and finally found it here. Mine issue was that the Ohms meter function was not happening, I would select the Ohms range and it would just show a, 'Ohm' symbol. Fixed it in two secs.! Cheers to all and a happy new one for 2021!!!
Offline Robert ContractsTopic starter
« Reply #28 on: May 04, 2021, 03:06:02 pm »
Evening,
Well came across the shortcut in browser and thought would read the comments - and can see Dave replied to this chat.
Here is a screen shot of email from Dave / then me replying back asking about the problem - not sure if have any photos of the meter boxed for postage , but least I know that i didnt enter wrong email address and just replied.
