Hey all
I have a MIDI footpedal used to switch patches for a guitar processor. There are two foot driven pedals that
pivot so you can rock the pedal back and forth.
On the underside of the pedal, there is a small 3/8" wide and 4" long strip of a flexible plastic with horizontal lines every 2mm or so.
The strip passes through a Sharp GP1A71R photointerrupter., Datasheet is here:
http://pdf.datasheetcatalog.com/datasheet/Sharp/mXuzuuu.pdfThis sends info to the main processor so you can adjust a parameter of one of the guitar patches in real time...
For example, if you set it to control the overall volume of the output signal, rocking all the way back gives you 0 output
and all the way forward 100% output,
Problem is that the clear plastic strip with the horizontal black lines has damage as it did not pass through the
gap in the GP1A71R cleanly....
Any thoughts on how to find a replacement?? Digikey once sold the GP1A71R, but now obsolete
Thanks
