If no sound can be easily solved by a reset button, there is no point in calling a tech for help.
There are at least 10 reasons for no sound.
In spite of various brands of av amps, working
principles of yamaha, pioneer, onkyo, sherwood and anthem are same
except denon and marantz
due to one more chip involved in digital decoding board.
How to troubleshoot? see pm. Waveforms and their names see photos and pm.
You must have an oscilloscope at least 40MHz. No oscilloscope no talk.
Single channel is more than adequate. Follow the steps and read them carefully.
Oscilloscope clip must be clamped to chassis or large heat sink mounted with 7 pairs transistors.
Different chips may be used, locate them and searching them on web so as to probe pins concerned.
Steps sent to you is a shortcut to distinguish which part of the digital circuit goes wrong.
Do not ask me why and no principle involved. At least 3 pages essay needed to explain principles, otherwise.
Digital board is the most difficult part in an av-amp.
A logical thought and sturdy knowledge is required.
No only hardware
but also software make it no sound.
This explains why no one is able to or dare to troubleshoot an av-amp digital board in
Hong Kong,
even authorized service department,
let alone Sham Shui Po, Apliu Street.
Steps involved are top-secret and do not take tech for granted he/she tells you how to do or even gives you a hint/hints.
In Hong Kong, authorized service department, told you to replace the digital board with $3480HKD = 447USD
BTW, direct sound can give a clue to you only if there are some speaker relay indicators on front panel such as onkyo.
Using this method to diagnose will , however, not help you.
Your amp does not have debug mode to diagnose digital problem.
Don't worry. Steps I have told you suitable for onkyo, yamaha, anthem, sherwood and pioneer.
Tell me the results if you want.
