Well, this is turning into a legitimate repair log now...
I ended up cleaning the back of the digital board where the replacement transformer taps were resoldered. This was done with 99 % isopropanol and q-tips because I don't have a way of acquiring methonal for the time being thanks to COVID. The way I clean is I start by dissolving the solidified flux and then I use a dry q-tip to clean towards the flux, starting at the perimeter of the liquid where the contamination is the least. The contamination doesn't spead far this way and I can reduce the amount of q-tips used as I have a recycle pile, in order of cleaniness. The process is repeated until I do not see residue in hard reflected light coming from a lamp. It is a huge improvement over what it looked like when I received the hardware. As it is the digital side of business, I doubt the flux will make an impact on performance, but this is a matter of pride!
The 80mm axial fan also needs attention because it makes clunky noises as if the axal is rubbing. Turns out the 126LF by ETRI is a sleeve type bearing, which breaks down much faster than a ball bearing type and can only be used in a horizontal position. They have a lifespan around 6 years of continuous operation. Sometimes you can fix these by opening them up and lubricating the shaft. This is done by rotating a circular plate on the opposite side of the sticker, removing an end plug that applies pressure to the shaft, removing a retaining ring and some washers. Unfortunately, the lubrication did not fix my problem.
With some searching, I managed to find the original datasheet for the fan. Obtaining a new one is difficult, so I decided to go with a ball bearing type alternative. The OA80AP-11-1TB from Orion seems to be a good candidate, although I do not know if it has a threaded grounding hole. You can either reuse the original power connector or purchase a 3-position connector (0009503031) from Molex with chrimp interconnectors (0008500108). I took these ideas from a blog:
https://www.nicolas.tv/blog/keithley-236-repair.
126LF-2182-000.pdf (97.88 kB - downloaded 74 times.)
OA80AP-11-1TB.pdf (204.45 kB - downloaded 49 times.)
The lithium ion battery from Duracell seems to be functioning as it reads 3 volts when using a DMM. The model number for this battery is DL2450, but you can find one under the name of CR2450 as well.
Another good thing about this instrument has the latest firmware package (I think). Is this a G version?
While preparing to clean the other side the the digital board, I found another problem that I still need to look into. There is a damaged component between the 'int dt 7130 SA100P delta delta U9502P' (Keithley designates this part as U12 in the KE 236 service manual) and the 'M45AB LM323K steel' (VR1). The component in question looks to be a capacitor based on schematics I found in the Keithley 236 service manual (C35). How would it break in this way? For some reason this component is not identified as a replacable part in the Keithley 238 service manual, so I am uncertain about the exact specifications of the component.
Can I assume that the capacitor for the Keithley 238 is the same as the C35 found in the Keithley 236 service manual?
Circuit Design Description Keithley Part Number
C35 CAP,.OluF,20%,50V,CERAMIC C-365-.01
Also, does anyone have schematics for the Keithley 238? I don't have them in the service manual version I own.
