i don't have pics, but at my old employer, we had three magnetizers (for magnetizing rotors for motor manufacturing)... Not relevant to the repair, but certainly a very impressive machine, was "Big Blue", a machine that took three full depth, full height 19 inch racks, with 2.5 of the rack space filled with capacitors, and the other half rack's worth of space containing the actual electronics... That was a BEAST of a machine, and did once put someone in the hospital when it vaporized a magnetizer winding that had been improperly connected...
Anyway, this is not about "Big Blue"... This is about a smaller unit that I once repaired. It had a mercury filled glass tube thyratron as it's trigger, and it had failed. It was an older machine, and the thyratron was pretty expensive for it. I was one of the site technicians, and I unbolted the thyratron, and started to "gently violently" shake it. I got some odd stares... I reassembled the unit, and it worked beautifully.
Over time, mercury would deposit on the outer glass, and sometimes on other internal structures. This eventually shorted it out, in such a manner, that it'd never allow the capacitor banks to fully charge... It'd always trigger early. Shaking the tube basically, "washes" the mercury residue off everything that does not need it, and coats everything that does need it... Well, thats the simple answer I gave, anyway. It was a simple fix, and the machine continued to operate right up until we were eventually bought out by a bigger company and our site closed down.
