Hello there i recently discovered that my favorite work tool uni-t ut139c true rms multimeter has gave out a ghost
the way i discovered it was even wierder
multimeter was working fine, i taped with it on something to move it, very soft, but it gone blank and after trying to turn it on was beeping and blinking
after opening battery compartment i discovered that most likely alkaline batteries has leaked. Batteries themeselves might have been there for 3-4 years already so i am amazed it still worked up untill now, but at least one of them spilled the juice all over the battery compartment and probably dameged something inside
i cleaned the thing quite well with ipa, put new batteries in and it kind of back to life only it now go and show wierd things
volts DC -0.3 - -0.5V
volts AC 0.004 probably fine but still interesting
mV DC -573.3 mV
mV AC - 0.00
ohms auto range go crazy megaohms shows 0.000 other ranges OL
temperature probe works but shows around 1 to 4 degree celsius too much the lower the temperatore the bigger the error
amps without load shows 0 on all ranges , didn't tested more
nvc worked contantly , now don't detect even close by wires
and a clamp shows -57 amps DC with no clamp
i have no idea which revision of the board is it but i can find that out probably
i know the case molding was made in 2013 based on the internal stamp but that might be missleading
i don't know what to check or how to clean it better, it doesn't seems to be missing anything or be dirty inside
is it time for a new meter?
