Sadly the error occured a few months after the end of the 5 year extended warranty.
And I called Siemens support:
Siemens Support: "With this error code a technician has to come and have a look at it."
Me: "OK, but what does it mean?"
Siemens Support: "That a licensed technician has to come and have a lokk at it."
Me: "I understand, but what is the technical fault? What does the error code say?"
Siemens Support: "Your error code means, that a Siemens technician has to come and have a look at it.
Me: "..."
Siemens Support: "Are you still there?"
And regarding the hobs: I measured resistance on all 8 induction hobs, the ones that work and the ones that don't. They all had the exact same resistance (0.3
), so I guess, they should be fine, right? Because they are basically just a wire wrapped around a metal coil, right?
Thanks for the answer,
best regards,
Niko
