Yeah... I read your comment... still it makes no sense to me...
When you have a TRIAC and a Relay in series, why would you turn on the Triac first? So that you can kill the relay contacts or what?
If the relay is operated when TRIAC is off, then you simply do not have to worry about arcing, subsequently damage. The relay is probably there anyhow,
in case the TRIAC is damaged.
Unless you did not get the part that the TRIAC I am talking about is IN SERIES with a relay on the board that I am wishing to repair. And that the only reason
that I mention the existence of the TRIAC is that I found out that in the power supply section of the oven / stove there is a ZCD circuit, and then I wondered
whether or not, they are using the ZCD circuit only for the TRIAC or also the relays.
Unless you knew already, mains frequency is pretty darn stable, so even with the slow relays, they might as well be doing some Zero-Crossing turn on with the
relays, after acquiring timing and "eye-balling" the turn on time of the relay.
And then I said, If they do not use the ZCD circuit to minimize relay damage over the time and they just switch on and off the relays, they might as well be aiming
at planned repair / obsolescence. If you know that out of 1000 samples, your relays turn on after x ms, then you might as well use this statistic to actually turn on the
relays x ms before the zero cross. It´s not an out of the world concept.
And there are no TRIACS parallel to relays on this board. There is only ONE TRIAC IN SERIES with a relay most probably for fan speed control. Nothing else.
I know the differences between TRIACs and relays... thank you!
