Hi everyone,
I have picked up a siglent sdg800 that doesn't respond to any key presses. When the unit is switched on, the display works and all the front panel LEDs light. It gets past the splash screen to show the settings of a sine wave output, but nothing more happens. I have got the unit apart and probed around a bit to find there is no activity at all in the front panel ICs related to the buttons and LEDs. There's multiplexers and shift registers on the front panel PCB but no serial data or clock pulses to be found anywhere. I checked for the correct supply voltages everywhere there's a labelled test point. I can't find a schematic or service manual online.
I've checked the front panel FFC is connected properly and continuity tested a few pins that I can follow from the shift registers and they are connected all the way back to the main board and then disappear inside the PCB layer stack and presumably go all the way to the microprocessor.
Do you think I should cut my losses and dispose of the unit, or is there something that could be done to fix it? I had a look around the other siglent threads but didn't find anything about the controls not working. I hope I haven't missed anything obvious!
Thanks very much
Ed
