Author Topic: Siglent SDM3045X power supply buzzing  (Read 2142 times)
Offline hammyTopic starter
« on: September 23, 2016, 06:39:44 pm »
Hi
any other SDM3045X owners out there?
The power supply of my device is constantly humming, even if it is turned off.
I'm just asking out of curiosity. Maybe I got a lemon.  ;)
Cheers
hammy
Re: Siglent SDM3045X power supply buzzing
« Reply #1 on: September 23, 2016, 06:54:16 pm »
I know different techniques to get rid of it.
- Soaking the windings of a transformet with superglue
- Soaking the stacked metal core U-pieces with superglue
- Cable-tie around the windings and/or the metal core
- Hot-Glue for coils
- foam rubber
Any other ideas/tips/tricks?  :-/O
Cheers
hammy
Offline Rasz
    • My random blog.
« Reply #2 on: September 23, 2016, 07:02:53 pm »
its siglent, probably some rust fell on the pcb and now hums sailor songs
« Reply #3 on: September 23, 2016, 08:38:11 pm »
It doesn't look that bad.  ;)
I like the features, and the big display. Ok, my 34401A is another weight class, but the histogram and trend chart are nice features in a DMM for that price.
« Last Edit: September 25, 2016, 08:22:38 pm by hammy »
Offline tautech
« Reply #4 on: September 25, 2016, 02:00:02 am »
I'm glad you like it hammy.
Yes they do hum, thay have an always on linear PSU and a soft switch type On button.
One I checked before placing this post, I can hear the transformer from ~100mm away.
The demo unit that I've had for nearly 2 years I've never noticed any transformer noise and yours is the first mention I seen of any Siglent SDM3*** PSU hum.
« Reply #5 on: September 25, 2016, 04:08:43 pm »
@tautech: Thank you for the cross reference
Today I had a look inside.  :-/O The transformer ist screwed directly to the case. I put a 2mm foam rubber between transformer and case and now the noise is gone.  :-+
Beside this:
- no rust inside
- the smd soldering looks very good
- the internal layout/floorplan is well made
I don't know if such transformers are only tested with 110V/60hz and Germany with 230V/50Hz is a corner case.  :-//
Cheers
hammy
