Electronics => Repair => Topic started by: little_carlos on March 22, 2022, 08:48:51 pm
Title: Siglent SDS1104x-e stuck at boot routine (SOLVED)
Post by: little_carlos on March 22, 2022, 08:48:51 pm
Hello everyone.
I own a Siglent SDS1104x-e which has been working ok for 3 years, bought it new.
Today, suddenly, it stopped working. It's stuck at the booting routine, here's what it does:
- Fan turns on
- Power button turns on
- Internal relay turning on and off
- screen shows nothing
- Rest of the buttons lights on
Already solved, here's the solution:
The firmware was never updated. So this is most probably an old firmware bug.
I had to start the scope with both channel 1 and channel 2 probes connected to the cal pin. This way for some reason started.
After that , updated to the newest firmware available and problem solved.
If any of you guys is thinking on buying a siglent scope, update the firmware as soon as new ver. are available
Title: Re: Siglent SDS1104x-e stuck at boot routine (SOLVED)
Post by: tautech on March 23, 2022, 09:40:04 am
Hello everyone.
- Fan turns on
Yes partially older FW is to blame however pressing Math, Math, Math fast and continuously at boot should get you past a boot freeze in these models.
For the latest FW update there is also an OSV2 update that enables the new NTP feature.
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS1xx4X-E_V6.1.37R8_EN.zip
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS1xx4X-E_OSV2_EN.zip
The OS update must be installed from the root of a USB stick and auto installs at boot.
The order of install doesn't matter.
Remember to delete the OS from the USB stick or it will run at each boot.
Post by: little_carlos on March 23, 2022, 03:13:42 pm
Thanks, ive already updated both Firmware and OS.
However, I did try the pressing math button quickly, but did not solved the issue
Post by: bdunham7 on March 23, 2022, 03:17:00 pm
Where did you get the idea to do that?
Post by: little_carlos on March 23, 2022, 03:49:33 pm
It thought that maybe internal calibration was failing, that's why I tried it. Not sure of why it did worked
Post by: tautech on March 23, 2022, 07:09:22 pm
Sometimes Math doesn't work first time and it normally pays to try it a few times as it's the normal fix for a boot freeze however Siglent do have a USB recovery package for theses scopes when Math doesn't work.
Post by: little_carlos on March 24, 2022, 05:16:40 pm
Thanks for the advice! Didnt knew about the USB recovery package, much appreciated!  ;D
Post by: JFunc on December 12, 2022, 02:01:15 pm
I have the same issue here. The USB recovery package - is it downloadable directly, or do we have to contact Siglent? I have tried a blank USB stick with the firmware on it, but it's still stuck at the 'Siglent' boot image, no matter what I try...
Post by: tautech on December 12, 2022, 07:26:55 pm
Welcome to the forum.
Have you used the Math, Math, Math button procedure when booting the DSO ?
We try this several times and quickly before trying further recovery methods.
Post by: JFunc on December 13, 2022, 11:59:43 am
Thanks for the reply!
Yeah - I've tried it numerous times, with no luck. It's a complete PITA, as I have a number of repairs piling up. Short of buying a new scope, is there anything else I can try?
Post by: tautech on December 13, 2022, 08:04:15 pm
Yep, we have tools to fix this.
Contact me via PM with your email and we'll have this sorted in no time.  :)
Post by: JFunc on December 16, 2022, 10:22:52 am
Hi tautech!
I received a lovely email from Tom at Siglent UK, who gave me a package to try, and it worked like a dream. Thanks for the help folks. It's groups like these that restore your faith in humanity!
Have a great holiday season chaps and chapesses!
Andy.
Post by: tautech on December 16, 2022, 10:44:37 am
Hi tautech!
Andy.
Always best if you can get local assistance and build a working relationship with them.
Enjoy !
