Author Topic: Siglent SDS1202X-E scope noise  (Read 301 times)
Offline howard123Topic starter
« on: January 21, 2023, 11:11:18 am »
Good morning
I have had this scope for 4 years and it quite suddenly developed a 308kHz sine wave noise signal superimposed on top of the regular signal. It is difficult to quantify the signal size as it remains a more or less constant size when the probe scale (*1, *10,*100) is changed, but does change size when the amplitude (volts/ cm) is changed. Everything else seems ok.
Anyone had a similar experience perhaps. I have thought to change the PSU caps. A PSU circuit would be very helpful.
thanks
