Author Topic: Siglent SPD3303X-E missing chip?  (Read 1151 times)
Offline R-1125FTopic starter
« on: November 11, 2022, 08:24:09 pm »
I bought a broken Siglent SPD3303X-E that someone had already been into.  It appears that an 8-pin chip on the main board is missing.  The problem is that I have no idea what the chip is. The space is marked UA9. The photos show where the chip is missing and the part number of for the board I am working on.  It does look like there may have been a chip there at one time.
Could someone tell me what the part number is for the chip that is supposed to be there?
I noticed in Dave's teardown video  on the SPD3303X that the space is populated.   It is my understanding that the hardware in the SPD3303X is identical to the SPD3303X-E.  Is this incorrect?
A schematic would be really useful here.   Are you listening Siglent?
Re: Siglent SPD3303X-E missing chip?
« Reply #1 on: November 11, 2022, 08:25:08 pm »
I add a photo of the board part number.
« Reply #2 on: November 11, 2022, 09:26:55 pm »
I got a message back from the seller that the chip is a TL072 dual opamp.
Offline tautech
« Reply #3 on: November 12, 2022, 11:15:27 pm »
UA9 is 741C
UA5 is TL072C
« Reply #4 on: November 12, 2022, 11:17:59 pm »
Thank you.  You saved me from installing the wrong chip. :-+
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #5 on: November 14, 2022, 06:51:06 am »
It also looks like CA3 and UA1 should be there ?
Might be also worth checking if CA26 and JA2 should be populated too ?
« Last Edit: November 14, 2022, 06:52:57 am by TheDefpom »
Cheers Scott
The following users thanked this post: tautech, 2N3055
Offline tautech
« Reply #6 on: November 14, 2022, 08:19:11 am »
CA3 = 100uF 35V
UA1 = L78L05
CA26 = Unpopulated
JA2 = Unpopulated
« Reply #7 on: November 14, 2022, 02:29:58 pm »
Thank you for the reply.
I had removed CA3 and UA1 to find a short.  I still have not found it.  The output to ground of the 78L05 measures about 1 Ohm resistance.  When I powered it on with the 78L05 in place, the voltage dropped to near zero.   With out the 78L05 in place, the input voltage is fine.  I am still hunting for the problem.  I see the same short conditions around UA20, UA9, QA19, and QA15.  I am really hoping that the AD7792 is not bad.   Any thoughts on this area would be appreciated.
But there's more. There is a similar short condition around the 3.3V (U2) regulator on the digital side.   With U2 removed, the resistance to ground is about 0.2 Ohms.  Again, hoping that the STM32 is not bad.  I have not started hunting on that side yet.
Could there be a common cause for these conditions?   Without a schematic is very hard to figure out.
Offline 2N3055
  • Country: hr
« Reply #8 on: November 14, 2022, 10:20:17 pm »
Look for a shorted MLCC capacitors ...
Dr. Richard W. Hamming
Offline TheDefpom
« Reply #9 on: November 14, 2022, 10:26:52 pm »
I was thinking the same thing.... more likely to happen than a failed IC (apart from the IC it kills in the process).
Cheers Scott
« Reply #10 on: November 15, 2022, 12:03:14 am »
I had that thought too.  I think I will try removing the caps that show the lowest resistance first while monitoring the resistance.  If there is no change in resistance I will put the cap back.  My last resort will be to apply power from a bench supply while and see what gets hot.
« Reply #11 on: November 15, 2022, 08:09:20 pm »
Well, this is not good.  I applied 5V to the shorted part of the circuit and the only thing that got hot was the AD7792BRUZ.   I removed the chip and the short was gone.  The only source I can find are ebay sellers in China.  I can't trust them.  The regular suppliers aren't going to have them for quite a while.
The next part is to find the short in the digital side.  If things go like this, the problem is going to be the STM32 processor.   Also, not easy to find.
Also, I seem to lost CA21 in the process.   Could someone tell me the value of this chip?  I suspect it is a .01.
