Author Topic: Silicon Transistors Equivalent for Marantz Amplifier  (Read 3638 times)
Offline massterTopic starter
« on: September 14, 2014, 12:09:19 pm »
Hello
I am trying to bring to life a Marantz PM400 audio amplifier.
The final transistors are faulty.
2SA1103 http://www.svntc.com/TPDF/1390.pdf
2SC2578 http://www.svntc.com/TPDF/2109.pdf
The problem is I can't find them where I live (Romania) and I need your help to find equivalents, preferably using the same packaging.
Thank you
Offline David_AVD
Re: Silicon Transistors Equivalent for Marantz Amplifier
« Reply #1 on: September 14, 2014, 12:17:42 pm »
How about checking the specs of the originals and then using Digikey's parametric filters to narrow down ones with similar specs.  Some important specs will be Vce, Ic, gain, package.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: September 14, 2014, 12:19:09 pm »
If Digikey is acceptable, maybe one of these would do,
http://www.digikey.com/product-search/en?pv16=14699&pv16=12311&pv16=10331&pv16=3436&pv16=13270&FV=fff40015%2Cfff80078&k=bjt&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
like, 2SA1186 (and the complement) seems similar, though a bit faster, so maybe you'd want a ferrite bead on the base terminal just in case.
But if we have no idea what counts as available...
Seven Transistor Labs, LLC
« Reply #3 on: September 14, 2014, 03:30:43 pm »
Thank you for replies.
The biggest supplier for parts in my area is http://www.tme.eu/en/
« Reply #4 on: September 14, 2014, 04:12:55 pm »
I have found these 2 transistors:
2STC5242 http://www.tme.eu/en/Document/53cf3b34ff283c6f437e3abc346921b3/6398412.pdf
2STA1962 http://www.tme.eu/en/Document/3adb6a03ac4f78bad4e0d1e4a60c67cb/7832268.pdf
Do you see any incompatible parameters ?
My other problem is they have to be paired for hFE, but I don't see that happening when I order online...
Offline KJDS
    • my website holding page
« Reply #5 on: September 14, 2014, 04:49:56 pm »
buy ten of each and match them yourself.
Offline dannyf
« Reply #6 on: September 14, 2014, 05:01:19 pm »
Motorolla if you don't have money;
5200/1943 if you don't have lots of money;
Sankens if you have lots of money.
