Doing a repair and suspecting the attached chip to be bad. Due to the level of difficulty to even get to the chip by desoldering a double stack of boards, I really need to know if it is bad.
The way it was connected in circuit are as such.
Vcc - pins 1,6, are connected directly to the source 12V power provided through a pin connector. There is no protection on those pins.
GND - pin 2, there is a paralleled diode and 10K resistor to ground, same as examples in data sheets.
CS-DIS - pin 5 has a 10k resistor to ground
Input - pin 3 hsa a 10K series resistor going back to an MCU output leg
Current sense - pin 4 has a 10k series resistor going back to another MCU pin.
I am really not familiar with the chip or its internals and only need to determine if it works or not. Probably easier to test a known good one first but.....
I need to know what voltages, resistors, etc I might use to give it a quick test. I don't plan to run much if any real load off the chip but I guess a simple 12V load would be easy. I really do not understand the input and current sense difference and use. I figured this was more or less a FET in which the MCU is just operating the gate. There seems to be more to this chip.
