Hi All,
I got a Simpson 260 series 6, looks awesome
On arrival it made some weird noise, like something was loose inside
So i opened it up to see what was going on.
In the battery compartment i found a small piece of bakelite, not sure where it came from
. But then, there was more (sounds), so i opened the backside, but nothing came out. Still a weird sound, coming from behind the glass. Carefully removed the glass, and ta-da! a small coper washer, that was ment to keep the glass in it place. So i cleaned the glass and put the thing back together (all good), but i'm now question how to deal with the Z/A screw?
I moved the "fork" on the meter carefully in the center (pointing down), and then turned the Z/A screw straight up. Put it together and tried it. Needle does move, but it doesn't feel right. I also tried to turn the peg straight down, but didn't feel it was any better.
I got two questions:
1. How should the Z/A screw be positioned? Any handy tips put this back together (its very hard to see)?
2. When / how do you actually use the Z/A screw?
Thank you!
