Ok, I heard back from him. The resistor values in his, match yours exactly. I guess they just decided to use the 269-2 board in both meters. You are correct on the resistor values. I have looked at Digikey, Mouser, and Newark. None of them have the 1.478k, or the 4.242k. You may have to just get as close as you can say like 1.47k, and 4.27k or series some together to get closer the values. I had to do that in my Simpson 260 series 3. I couldnt get he exact values for the bobbin resistors, so I had to series 2 wirewound resistors to get as close as I could. I will look at a couple of other places and see what I come up with.
