I routinely repair BLDC controllers. Customers mail me their controllers for repair and often it's fairly easy to find and repair a problem.
But every once in a while I get a controller, which appears to work and I find it difficult to test it without the motor. Customers don't want to mail in the motor due to weight/size related costs.
So what I'm looking for is a way to implement a rough BLDC motor simulator. I'd have the controller on one side and my regular load tester on the other side. In between, there would be a circuit which takes in the three wires from the BLDC controller and the two wires from the load tester and acts like a typical BLDC motor effectively implementing the 3 phase motor timing sequence. The end result is that the controller thinks that it's running a real motor, the current flows through the controller testing the capacity and I can see the amount of current being used on my load tester.
Ideally, I'd like to find a cost effective off the shelf implementation. But I'm not against implementing my own circuit. I looked far and wide but I can't seem to find anything. But then again, BLDC is not my specialty.
