Author Topic: Slow start circuit 115VAC to 230VAC conversion  (Read 598 times)
Offline ballenTopic starter
« on: October 27, 2024, 07:38:05 pm »
Putting this into "repair" though it is really "modification".
I have a Parasound HCA-1200 amplifier from the 1990s.  I bought it in the USA but now live in Germany.  The amp is set up for 120V 50/60Hz, and I have used it in the past with a 240V/120V transformer. I'd like to eliminate that conversion transformer and if possible power it directly from the mains.
While the amplifier has no provision to switch input voltages, I just took a look at the large (1kVA) torroidal transformer that provides DC.  The good news: the primary comes out as four wires, with two pairs in parallel.  So I think it is likely that there are two primary coils, currently being run in parallel, and that if I put them into series then I can drive the transformer directly from 230V.
The amplifier has a soft-start circuit.  When initially turned on, there is a 10 ohm 30W resistor in series with the primary.  Then, when the DC voltage (from a separate low-current secondary winding, time constant set by a 22uF capacitor and a 220k resistor, so a couple of seconds) has risen to a reasonable level a relay closes and shorts out the 10 ohm resistor.   I assume this is to keep the input surge current down and also to provide a gentler start to the amplifier itself.
My question: if I am correct that if there are two primary windings, currently in parallel, and that all I need to do is put them in series, then is it also correct that I should replace the 10 ohm 30W resistor with a 20 ohm 30W resistor, to maintain the soft start?  (If so, I will probably get another 10 ohm 30W resistor and put it in series, thus ending up with a 20 ohm 60W resistor.)
Snapshot of the relevant bit of the schematic is attached.  The resistor in question is R05.  Note that this schematic does not show the primary as made of two separate windings.
Thanks,  Bruce
2415901-0
« Last Edit: October 27, 2024, 09:56:22 pm by ballen »
Offline inse
Re: Slow start circuit 115VAC to 230VAC conversion
« Reply #1 on: October 27, 2024, 08:57:11 pm »
In principle the conversion should not be a problem, just make sure you have the polarity of the primary windings correct.
With 10 Ohms of inrush limit you usually should not trip a 16A breaker, I would try it with the existing value.
The following users thanked this post: ballen
Offline Psi
« Reply #2 on: October 27, 2024, 09:00:30 pm »
Yep, but as others have said make sure you get them in series around the right way.
« Reply #3 on: October 27, 2024, 09:53:31 pm »
Inse, Psi, thanks for your replies.
Regarding the correct polarities of the two primaries, yes, I'll be careful to ensure that the series connection keeps the relative direction of current flow in the two windings the same as it is now.  I'll use the standard trick of digging out an incandescent bulb and wiring that in series with the (new) primary on first power-up.  If I have it right the bulb will stay dim, if I got it wrong the bulb will light.
Inse: Coming back to the resistor question, since the transformer is rated 1000kVA that's about 8A continuous in the primary, which means that as designed the 10 ohm resistor will limit total inrush current to about 12A.  If I leave that resistor as is, then the inrush current might be as much as 24A, assuming for the moment that I neglect the transformer self-inductance.  That is high for a typical household 16A circuit, no?
Offline inse
« Reply #4 on: October 28, 2024, 03:30:14 am »
With a guesstimated resistance of 2Ohms of the primary in series with 10Ohms, the initial current will be 20A for few seconds at max.
This shouldn’t trip the breaker.
But to be sure, go for 20 Ohms.
« Reply #5 on: October 28, 2024, 08:37:07 am »
One further question.  The relay (RY1) is a DPDT with a 12V DC coil.  According to the printing on the relay, the contacts are rated 120VAC 5A.  So I suspect that the contact pair is used in parallel to handle up to 10A continuous.
It seems like a good idea to replace this with 230VAC-rated contacts, but not imperative for testing.  Is that right or should I be more cautious and replace the relay before doing any testing?
Offline Datman
« Reply #6 on: October 28, 2024, 09:26:23 pm »
On the contacts of the relay there is only the voltage on the resistor!
Offline inse
« Reply #7 on: October 29, 2024, 04:50:21 am »
Right, and when the inrush has dropped, there is low current through and little voltage across the resistor.
So when the contact closes there is not much stress, opening and closing under load is what wears down the relay.
« Reply #8 on: October 30, 2024, 08:21:35 am »
OK, thanks for the feedback, I'll leave the relay as is.
