Author Topic: Slow-to-start Holmes windows fan  (Read 1573 times)
Offline 13hm13Topic starter
« on: May 19, 2022, 07:30:41 am »
A very common window fan type, and has been for at least two decades. This one purch'd new in 2008, but with relatively low hours.
PROBLEM: Takes a while (20 min) for fan to start working correctly. During that time, both fans just barely turn when multi-mode (electronic) button is pressed. Then (after 5 min) it will go into speeds (1, 2, 3) but only for second ... before off'ing.
But  then (after 15 min of being plugged in) the unit works perfectly, EXCEPT, the fans (either / both) won't spin in reverse (exhaust). When switched, to EXHAUST, they stop and hum/buzz.
IMPORTANT-----BOTH FANS (MIS)BEHAVE THE SAME WAY (including non-operation on INDEPENDENT reverse switches)
Took the fan apart but haven't tested anything yet (e.g., capacitance, ESR). I've heard that the starting cap (black, rectangular 2.5 uF, 250 v) can  cause issues. But these are plastic (poly/ mylar???) caps, albeit cheap Chinese. There is single low-voltage electro cap on the PCB, but it does not look bulged.
« Last Edit: May 19, 2022, 02:49:06 pm by 13hm13 »
Offline TheMG
Re: Slow-to-start Holmes windows fan
« Reply #1 on: May 19, 2022, 01:31:02 pm »
Plastic film capacitors can degrade too. Every time they are hit with a voltage transient (surge) they can lose a bit of their capacitance, little by little with every transient the capacitor is subjected to.
How does the electronic speed control work? Is it switching between different speed windings on the motors, or using some kind of TRIAC circuit? Does the control board use a capacitive dropper power supply? If so, don't forget to check that cap too as it's likely a film cap also and since it receives power at all times the unit is plugged in, would definitely be vulnerable to degradation by surges.
Note: I can only see the very first picture in your post, none of the other ones work.
« Reply #2 on: May 19, 2022, 02:50:58 pm »
That's eevblog's DUMB forum engine's fault. Always makes one do more work posting stuff than necessary. Sigh .... I modified .... LOOK AGAIN!
Offline tunk
  • Country: no
« Reply #3 on: May 19, 2022, 04:30:01 pm »
Are you sure the fans themselves are ok?
Just opened an ATX psu with a non-rotating fan.
Oiled the bearing, now it starts slow and then
the RPM increases after a few minutes.
Offline james_s
« Reply #4 on: May 19, 2022, 05:56:56 pm »
First thing I'd check is the motor bearings, do the fans spin freely? It's very common for the lubrication to gum up and then the motor will spin slowly until it warms up and gets loose.
Offline Gyro
« Reply #5 on: May 19, 2022, 06:14:42 pm »
Yes, I think it's going to be either the motor run (not "starting") caps self healing themselves to death - they will have been hit with the same number and size of transients, or lubrication failure.
I wouldn't be at all surprised if it was a combination of both.
Best Regards, Chris
« Reply #6 on: May 19, 2022, 06:39:36 pm »
It ain’t the bearings (technically bushings in this case) or lube. Have had mechanical issues on other, similar fans— treated several times.
That’s the first thing to check — give the fan a finger nudge and watch how long that spin holds inertia.
Come on folks…no dumb, obvious questions.
Offline Gyro
« Reply #7 on: May 19, 2022, 06:47:56 pm »
Err, do you want help / ideas from people here or not?...  If not, then don't ask!
P.S. If you want more detailed suggestions than what are possible from the photos that you have supplied, then reverse engineer the PCB and internal wiring and post the schematic.
« Last Edit: May 19, 2022, 06:57:20 pm by Gyro »
Best Regards, Chris
« Reply #8 on: May 19, 2022, 07:31:10 pm »
Oy, guv .... 'ow you doin' taday? Yer 'ponse iz weird!! Did ya pass yer A-Levels, guv?
Offline Gyro
« Reply #9 on: May 19, 2022, 07:45:33 pm »
Looking at your posting history, I notice that many of your recent posts are sarcastic and antagonistic, including this one [EDIT: and your "SCHWEIN HUND" avatar]. I'd be careful if I were you.
Nobody here owes you answers to your questions, so do us all a favour and be a good boy.
« Last Edit: May 19, 2022, 08:31:18 pm by Gyro »
Best Regards, Chris
The following users thanked this post: james_s
« Reply #10 on: May 19, 2022, 09:38:53 pm »
Oy, guv ... oh, you betcha on all yer INSIGHTFUL comments. 'Pose me photos are deep fakes .... ya know ... "sarcastic and antagonistic".  ...um  'avin' a bit of a wanq, are ya, guv? ;)
ANYWAY, the problem is solved. My first hunch was right ... that it ain't the poly's. The answer is in the photo(s) and in my first paragraph.
Offline james_s
« Reply #11 on: May 19, 2022, 09:49:10 pm »
Sorry I seem to have misplaced my crystal ball so I was not aware that you had already checked these things. Are you aware that there are people of multiple skill levels on this worldwide forum that may not be as enlightened as you are? I'm not a moderator but I'll point out that people with your attitude tend to be banned sooner or later, or at the very least you will end up on the ignore list of a lot of the more experienced members for being needlessly rude, you're going on to mine now due to your attitude in this thread. If you want free help, don't be a dick to people that are trying to help you.
Offline themadhippy
« Reply #12 on: May 19, 2022, 10:17:23 pm »
Oiled the bearing,
not  always a good idea as the oil washes out the original grease,and whilst initially things seem ok,after a while the oils gone and you've a nice dry bearing getting ready to lock up.
Offline james_s
« Reply #13 on: May 19, 2022, 10:21:49 pm »
Oiled the bearing,
These things are normally sintered bronze, they'll be oil impregnated in most cases, either "permanently" lubricated or with a felt to absorb oil. I don't think I've seen one that used grease.
Offline BrokenYugo
« Reply #14 on: May 19, 2022, 10:42:51 pm »
Any one I've seen has oil wicks to keep the oilite material (which is a bronze wick) saturated with oil.
« Reply #15 on: May 19, 2022, 11:05:57 pm »
Whoa, Nelly! Now where in EEV Forum TOS does it say anything about a paid option (I.e., not FREE)?
Offline amyk
« Reply #16 on: May 20, 2022, 02:23:13 am »
The country flag is a good indicator. It's German humour... takes a bit of getting used to. ;)
Going back to the problem, my bet is on the electrolytic - once it has warmed up sufficiently, its ESR drops enough to smooth the supply to the MCU and it doesn't keep resetting.
Offline james_s
« Reply #17 on: May 20, 2022, 03:24:31 am »
There are lots of other Germans on here that are not abrasive and demanding.
That's a reasonable guess, can't say without testing the ESR or replacing it, although I would expect other symptoms like a dim/flickering display or obvious signs of resetting.
The following users thanked this post: Gyro
Online Shock
« Reply #18 on: May 20, 2022, 11:41:52 am »
There is old adhesive on the pcb.
Offline Gyro
« Reply #19 on: May 20, 2022, 12:45:42 pm »
Either way, I don't find him humorous. I've added him to my (very short) ignore list too.
Best Regards, Chris
« Reply #20 on: May 21, 2022, 04:13:26 am »
Yes ... that electro cap (6.3v 1000uF). If you look at the photo, you can kinda see it swelling at top. All I had was a 50v 330uf. Which worked.
BTW .... I ain't German. Just took it as a furron lang. Teacher told us never to use certain slangs.
About no fun with Germany … well you’ll have to remind the BBC.
https://youtu.be/eHxTiMU0aLk
« Last Edit: May 21, 2022, 07:34:56 pm by 13hm13 »
