Author Topic: Small mains socket (case mounted) and plug recommendation  (Read 1900 times)
Offline owieccTopic starter
    • Google scholar profile
« on: July 03, 2015, 02:12:26 pm »
Do you have any recommendations for a small plug/socket 230V rated. I will use it on a blade saw. One of the adapters needs 230V and is now connected to a wall socket. I was thinking on replacing that and taking the power from a saw unit. Current drawn by the adapter is extremely small, well below 1A.
The saw is quite small and I would like to put a small socket on its case. There is also water involved in the cutting so ideally the socket should be splash resistant. Do you have any recommendations? I found a few already but they were either huge 16A rated or super expensive.
Offline wagon
Re: Small mains socket (case mounted) and plug recommendation
« Reply #1 on: July 05, 2015, 02:27:22 am »
Hiding from the missus, she doesn't understand.
Online Psi
« Reply #2 on: July 05, 2015, 06:00:38 am »
As long as that one is for mains input  :-DD
Offline dom0
« Reply #3 on: July 07, 2015, 05:43:48 pm »
Hirschmann ST series? 2+PE is available and suitable for mains.
Offline wagon
« Reply #4 on: July 09, 2015, 12:58:20 am »
They are rated to 250V.  Don't know about 'approval', however.
