So today I had a garage sale near my house, so I thought, why not go and maybe pick up some cheap electronics that I can salvage parts from. When I arrived there, I spotted a small amplifier. Curiosity got the better of me. I bought it for 2 bucks and happily took it home. Upon the first glance the condition of the amplifier is good. The 240VAC is removed/cutoff, and at the back there seems to be only room for two speakers and one which doesn't work according to the little tag. However the condition of the front panel was excellent, all it needed was some alcohol to clean it off and looked good as new! I continued to take it apart. On inspection I noticed that there are two exactly the same looking boards, which are the amplifier circuits for the left and right speakers. I continued to inspect the circuitry. The hot wire was connected to a large switch which is switched on at the front and then the wire from the switch went to the transformer. The transformer itself has two 115V input parts, the were connected in series so it can work with 240VAC from the wall outlet. The transformer had two outputs, one was 4V 0.2A for the on indicator lamp and the other one was 135V 0.5A for the rest of the circuitry. I assume that since it was made in Japan they had 115V there, hence the 115V transformer. The neutral wire went to a fast blow fuse which appears to be 0.5A and then connected later on to the transformer. The ground was connected to the chassis and to the surrounding metal bit of the capacitor. I continued to test whenever the fuse works. It does, just needed a little bit of a clean from oxidation. Then I tested the lamp, I noticed that it was powered using 4V from the transformer, but it was rated for 8V, I guess there wasn't any need for a brighter lamp. All of the boards were raised above the metal case to prevent short circuit. Everything was bolted on using a philips screws (+) and sometimes use of various bolts.
