Author Topic: SMD cap alternative - motherboard has extra set of pads  (Read 801 times)
Offline sirlemonhead
  • Country: ie
« on: March 28, 2019, 08:05:00 pm »
I have an old computer motherboard from 1992 and I've just removed all the SMD capacitors as they were leaking, with the aim to replace them. I've noticed that each capacitor seems to have a second set of much larger pads. I've tested these for continuity and they appear to be alternative capacitor pads.
You can see them here - the thin rectangular pads are from the original caps, the larger square ones are either to the side of or above/below the original pads.
See picture:
https://www.dropbox.com/s/1ryd6329nvzidxh/dellsmdcaps.jpg - pardon the flux gunk/residue
I was wondering - why is this? Is this designed for an alternative capacitor type? If there were MLCCs or something longer lasting I could put on that would be great, especially as some of the alternative pads are oriented in much easier to access spaces than the original pads!
Thanks!
Offline wraper
  • Country: lv
Re: SMD cap alternative - motherboard has extra set of pads
« Reply #1 on: March 28, 2019, 08:08:14 pm »
Most likely they are for tantalum SMD capacitors.
Offline pbarton
« Reply #2 on: March 28, 2019, 08:56:04 pm »
To reduce component sourcing risks...…
https://www.eetimes.com/document.asp?doc_id=1121949#
Offline LateLesley
  • Country: scotland
« Reply #3 on: March 28, 2019, 09:14:50 pm »
That's a very old article from June 1999.
Capacitor prices on the rise again
By Bettyann Liotta, 06.18.99
Offline pbarton
« Reply #4 on: March 28, 2019, 09:47:52 pm »
That's a very old computer motherboard.
The ‘buyers’ in manufacturers ‘Material Supply’ departments frequently experienced difficulty in securing supplies of certain components during the late 1990’s.
It’s not uncommon to find that PCB layouts were designed to accommodate equivalent or substitute parts.
« Last Edit: March 29, 2019, 08:34:58 am by pbarton »
The following users thanked this post: LateLesley
  • Country: ie
« Reply #5 on: April 02, 2019, 07:36:22 pm »
Thanks, that's good to know!
Would I be best off just using electrolytics? or is there anything else I can use worth considering over them or the tantalums?
Offline Rasz
    • My random blog.
« Reply #6 on: April 23, 2019, 04:27:40 pm »
