Author Topic: SMD CODE  (Read 1932 times)
Offline BMTELECTopic starter
  • Country: tr
SMD CODE
« on: August 04, 2022, 09:53:01 am »
Hi everyone,
There is a SOT-23 and 3 pin component. SMD CODE is C8JZB and tehere is a = sign under J letter.
I searched this SMD CODE from web pages. I think its a RT916A-18GV but I am not sure. Could anybody help to me. AM I right or not?
Thank you.
Offline gamalot
  • Correct my English
    • Youtube
Re: SMD CODE
« Reply #1 on: August 04, 2022, 11:22:30 am »
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
  • Country: tr
Re: SMD CODE
« Reply #2 on: August 04, 2022, 02:09:13 pm »
Hi Gamalot
Firstly I would like to say "thank you"
I thought as like you before and I ordered si2318ds and soldered it. When I applied power to the system it self-protected and shut down. I asked for this help because I was not sure about it. Could this not be? Please do not misunderstand. When I get a response from you, I will put the second one I have on the card. I am sure the fault is not elsewhere.
Best regards
haldun
Offline gamalot
    • Youtube
Re: SMD CODE
« Reply #3 on: August 04, 2022, 10:41:45 pm »
If you have another Si2318DS in your hand, you can clearly see that it is the same model as the original one on the PCB, right?
There must be something else wrong.
If you are still worried, you can take a clear picture of the original one and the one you bought, and many people here will help you identify it.
Offline fzabkar
Re: SMD CODE
« Reply #4 on: August 04, 2022, 11:17:06 pm »
What is U20?
Offline gamalot
    • Youtube
Re: SMD CODE
« Reply #5 on: August 05, 2022, 12:16:33 am »
What is U20?
Should be an oscillator/transformer driver or something like that, R41 should be a current sampling resistor.
  • Country: tr
Re: SMD CODE
« Reply #6 on: August 05, 2022, 10:10:48 am »
Hi
U20 is MAX668EUB.
Thanks
  • Country: tr
Re: SMD CODE
« Reply #7 on: August 05, 2022, 10:18:31 am »
Original part smd code: C8JZB
Ordered part smd code:N48
Offline gamalot
    • Youtube
Re: SMD CODE
« Reply #8 on: August 05, 2022, 10:48:01 am »
The one you bought with the N48 code should be LN4812LT1G, it should be no problem although it is not the same model as the original one.
  • Country: tr
Re: SMD CODE
« Reply #9 on: August 05, 2022, 03:41:33 pm »
Many thanks for your detailed information.
Regards,
Offline fzabkar
Re: SMD CODE
« Reply #10 on: August 05, 2022, 05:24:27 pm »
I would check the resistance of C20 and C21. These appear to be the positive and negative outputs of the DC-DC converter.
https://datasheets.maximintegrated.com/en/ds/MAX668-MAX669.pdf
« Last Edit: August 05, 2022, 06:53:26 pm by fzabkar »
  • Country: tr
Re: SMD CODE
« Reply #11 on: August 05, 2022, 07:10:24 pm »
Let me check.
I will reply again
Thanks
  • Country: tr
Re: SMD CODE
« Reply #12 on: August 05, 2022, 07:20:16 pm »
I would like to additional information.
Problem:  I am measuring -7V in leg of D5. This voltage is expecting voltage and its ok but I am reading +2.0V in the D4. It should be +7V.
C8JZB is warming.
Thanks
Offline fzabkar
Re: SMD CODE
« Reply #13 on: August 05, 2022, 07:42:14 pm »
C8JZB is warming.
I suspect that these supply rails would be used by the analogue section of the circuit, possibly op amps. I would use your meter's continuity test to determine which ICs are powered from these supplies.
What are the resistances between ground and each of these rails? I would think that in a working circuit they should be similar. I would also confirm that D4 is not leaky.
When the circuit is regulating properly, the FB pin (5) of U20 should be sitting at +1.25V.
« Last Edit: August 05, 2022, 07:49:01 pm by fzabkar »
  • Country: tr
Re: SMD CODE
« Reply #14 on: August 05, 2022, 08:13:47 pm »
You will let you know from the result
Thank you
