Author Topic: SMD component decode problem (LD mark)  (Read 724 times)
Offline Krzysztof87PLTopic starter
« on: June 08, 2022, 07:25:14 am »
Hi, I have a huge problem with decode of SMD component. It's element Q36 .LDt (LD*) probably SOT 363 or SC70-6 package. I found NL7SZ18DFT2 but it's multiplexer, MOSFET BF1202R only available on SOT143R, SOT143B, SOT343R, package (only 4 pins package). The photo of PCB on attachment.
Regards Krzysztof
Offline fzabkar
Re: SMD component decode problem (LD mark)
« Reply #1 on: June 08, 2022, 09:59:43 pm »
Could you trace out the circuit in the vicinity? Can you identify the ground and supply pins? That might help to visualise what it is.
I have a feeling that "t" may be a code which identifies the manufacturing location, as in parts made by NXP.
Are the other components American or Japanese or something else?
« Reply #2 on: June 09, 2022, 12:24:59 pm »
Other components are from Texas Instruments, NXP, National Instruments, ST, Linear Technology.
Yes, but I can found only track close to damaged transistor it's multilayer PCB (probably 6 or 8 )
Offline gamalot
  • Correct my English
    • Youtube
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
The following users thanked this post: cozza, Krzysztof87PL
« Reply #4 on: June 10, 2022, 06:05:09 am »
@gamalot this is it! Thanks you very much for support!
