Author Topic: [solved] smd component identification CCA48  (Read 1273 times)
Offline mnt22Topic starter
  • Country: jo
« on: October 29, 2018, 02:09:30 pm »
I need help with this device goes by "CCA48"  :-//
Thanks for everyone
« Last Edit: October 29, 2018, 07:28:33 pm by mnt22 »
Offline ElecSeb
Re: smd component identification
« Reply #1 on: October 29, 2018, 05:36:17 pm »
Torex - XC9235B08C4R-G
https://www.torexsemi.com/file/xc9235/XC9235-XC9236-XC9237.pdf
Do not always look at the last digits, these are 9 out of 10 times part of date code.
so when looking on CCA25, go like this:
CCA25
CCA2
CCA
And when you find a datasheet go through it to check if the marking is corresponding your CCA25 (date mark is 9 out of 10 times names in the datahseet)
The following users thanked this post: mnt22
  • Country: jo
« Reply #2 on: October 29, 2018, 07:23:39 pm »
CCA25
CCA2
CCA
Thank you very much ElecSeb  :phew:
